Zum Hauptinhalt wechseln
Ridgid R82005 Housing Assembly Replacement
Was du brauchst
  1. Ridgid R82005 Housing Assembly  Replacement, Housing Assembly: Schritt 1, Bild 1 von 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005 Housing Assembly  Replacement: Schritt 2, Bild 1 von 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Housing Assembly  Replacement: Schritt 3, Bild 1 von 2 Ridgid R82005 Housing Assembly  Replacement: Schritt 3, Bild 2 von 2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005 Housing Assembly  Replacement: Schritt 4, Bild 1 von 2 Ridgid R82005 Housing Assembly  Replacement: Schritt 4, Bild 2 von 2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
Abschluss
To reassemble your device, follow these instructions in reverse order. Also reinsert the battery to make sure the drill has power.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Cominos
376 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S1-G2, Leahy Spring 2019 Mitglied von USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 231
