Zum Hauptinhalt wechseln
Ridgid R860054 Disassembly
Was du brauchst
  1. Ridgid R860054 Disassembly, Ridgid R860054 Disassembly: Schritt 1, Bild 1 von 2 Ridgid R860054 Disassembly, Ridgid R860054 Disassembly: Schritt 1, Bild 2 von 2
    • Using a T10 Torx security bit, remove the ten screws from the housing assembly.
    • All of the casing screws are the same length and require the same bit.
  2. Ridgid R860054 Disassembly: Schritt 2, Bild 1 von 2 Ridgid R860054 Disassembly: Schritt 2, Bild 2 von 2
    • Separate one half of the drill casing from the other by gently pulling both halves apart.
    • Once one half of the casing is removed, be careful! If the components are directed towards the ground, they could fall out.
  3. Ridgid R860054 Disassembly: Schritt 3, Bild 1 von 3 Ridgid R860054 Disassembly: Schritt 3, Bild 2 von 3 Ridgid R860054 Disassembly: Schritt 3, Bild 3 von 3
    • Remove the plastic speed switch and forward/reverse switch by softly lifting them from the casing.
    • Remove the internal components of the drill by lightly pulling on the drill chuck.
    • All of the other electronic components are attached to the chuck, and will come out with it.
  4. Ridgid R860054 Disassembly: Schritt 4, Bild 1 von 1
    • The main section of the drill should have the trigger, light indicator, and battery prongs all connected via wire. There should be two plastic switches separated from the rest of the body.
Abschluss
gage.anastasio
339 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-1, Shaddix Spring 2023 Mitglied von UMass Dartmouth, Team 1-1, Shaddix Spring 2023
UMASSD-SHADDIX-S23S1G1
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 30
Insgesamt: 267
