Einleitung
This guide will show you how to completely disassemble your Ridgid R860054 drill.
If you are using this guide to assist with a repair, we recommend checking out our troubleshooting guide. There you may find a guide that is more specific to your needs.
Make sure to remove the battery from the drill before beginning the tear down.
Was du brauchst
Using a T10 Torx security bit, remove the ten screws from the housing assembly.
Separate one half of the drill casing from the other by gently pulling both halves apart.
Remove the plastic speed switch and forward/reverse switch by softly lifting them from the casing.
Remove the internal components of the drill by lightly pulling on the drill chuck.
