Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
If you blow a fuse in the impact driver you only have to open up the device and replace the broken fuse with a new one.
  1. Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • The rubber cover is securely attached to the housing so some force is necessary.
    • When putting the rubber cover back, remember that its orientation is important. Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
  2. Remove the plastic cover with your hands. The plastic cover should be much easier to remove than the rubber cover. There is no need to force it off. Remove the plastic cover with your hands. The plastic cover should be much easier to remove than the rubber cover. There is no need to force it off.
    • Remove the plastic cover with your hands. The plastic cover should be much easier to remove than the rubber cover. There is no need to force it off.
  3. Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver. Use a firm grip to peel the the back panel off. It is sealed tight and requires a good amount of force to remove. Use a firm grip to peel the the back panel off. It is sealed tight and requires a good amount of force to remove.
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel the the back panel off. It is sealed tight and requires a good amount of force to remove.
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. Unscrew the eight 15 mm T10 Torx screws from the housing The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead use a conventional screwdriver that fits.
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead use a conventional screwdriver that fits.
  6. Place the driver flat on a table before completely separating the two halves of the housing so components don't fall out during opening.
    • Place the driver flat on a table before completely separating the two halves of the housing so components don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger .
    • The housing is easier to remove if you pry from multiple sides.
  7. Do not remove the direction switch. It isn't necessary. Pull out all electrical components from housing by hand. First, lift out the motor. Next, follow the wires, lifting out components until all components are outside of the housing.
    • Do not remove the direction switch. It isn't necessary.
    • Pull out all electrical components from housing by hand. First, lift out the motor. Next, follow the wires, lifting out components until all components are outside of the housing.
    • With two exceptions all of the components should come out of their respective slots with ease and require little force to lift out. The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • When reassembling remember to precisely place all components in their correct slots with their correct orientations.
  8. Identify the translucent orange fuse cartridge connected by a thick red wire and a thick white wire.
    • Identify the translucent orange fuse cartridge connected by a thick red wire and a thick white wire.
  9. Firmly grasp the orange fuse cartridge and pull it out of its socket. The fuse does not come out easy, don't be afraid to pull hard to get it to come out. The fuse does not come out easy, don't be afraid to pull hard to get it to come out.
    • Firmly grasp the orange fuse cartridge and pull it out of its socket.
    • The fuse does not come out easy, don't be afraid to pull hard to get it to come out.
  10. Insert the new fuse cartridge. Insert the new fuse cartridge. Insert the new fuse cartridge.
    • Insert the new fuse cartridge.
Abschluss
Tommy Lovelace
201 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 15-5, Amido Spring 2015 Mitglied von Cal Poly, Team 15-5, Amido Spring 2015
CPSU-AMIDO-S15S15G5
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 656
