Zum Hauptinhalt wechseln
Rienok S1 Mini Top and Bottom Rings Replacement
Was du brauchst
  1. Rienok S1 Mini Top and Bottom Rings Replacement, Grille: Schritt 1, Bild 1 von 2 Rienok S1 Mini Top and Bottom Rings Replacement, Grille: Schritt 1, Bild 2 von 2
    • Start with the buttons panel up and facing you.
    • Wedge in one iFixit opening pick, and apply outward pressure to pop out one side of the grille.
    • Using a second pick, slide from the first pick towards the opposite end until one whole side is popped out.
  2. Rienok S1 Mini Top and Bottom Rings Replacement: Schritt 2, Bild 1 von 1
    • While holding the other side open so it doesn't snap closed, wedge in one opening pick into one corner of the closed side.
    • Apply outward pressure until that side also pops out.
    • Using a second opening pick, slide from the first one until both sides have popped out.
  3. Rienok S1 Mini Top and Bottom Rings Replacement: Schritt 3, Bild 1 von 1
    • Pull outward on one end, while holding the other open.
    • Pull in the opposite direction on the top or bottom rings while slightly rotating the center until the whole grille is removed.
  4. Rienok S1 Mini Top and Bottom Rings Replacement, Top and Bottom Rings: Schritt 4, Bild 1 von 2 Rienok S1 Mini Top and Bottom Rings Replacement, Top and Bottom Rings: Schritt 4, Bild 2 von 2
    • Wedge an iFixit opening pick into the space between the ring and the housing.
    • Insert a Jimmy into the gap created.
    • Apply an out-and-upward pressure with the Jimmy to disconnect the plastic clips surrounding the ring.
    • Work the Jimmy around the ring, disconnecting the clips along the way until they are all disconnected.
    • It may help to insert additional opening picks as you go to keep the previous clips from reconnecting.
  5. Rienok S1 Mini Top and Bottom Rings Replacement: Schritt 5, Bild 1 von 2 Rienok S1 Mini Top and Bottom Rings Replacement: Schritt 5, Bild 2 von 2
    • After removing the first ring, turn the device to the other side.
    • Repeat the previous step to remove the second ring.
Abschluss
Zoey S.
781 Reputation
5 Anleitungen geschrieben
CSU Los Angeles, Team 7-1, Kershman Spring 2025 Mitglied von CSU Los Angeles, Team 7-1, Kershman Spring 2025
CSULA-KERSHMAN-S25S7G1
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 116
