Einleitung
This guide is for the purpose of demonstrating how to replace a Ring Outdoor Security Cam battery. One of the most common problems in a Ring camera is expired battery life. To keep the device running smoothly, make sure to replace the battery every so often. There are no safety hazards for this fix, and the difficulty level is moderate. It's an easy, fast fix with no specific experience or knowledge aside from screws.
Was du brauchst
Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
