Zum Hauptinhalt wechseln
Ring Outdoor Security Cam Camera Replacement
Was du brauchst
  1. Ring Outdoor Security Cam Camera Replacement, Camera: Schritt 1, Bild 1 von 1
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Camera Replacement: Schritt 2, Bild 1 von 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Camera Replacement: Schritt 3, Bild 1 von 1
    • Use an opening tool to pry the back plate off of the device.
  4. Ring Outdoor Security Cam Camera Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Camera Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  6. Ring Outdoor Security Cam Camera Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
  7. Ring Outdoor Security Cam Camera Replacement: Schritt 7, Bild 1 von 1
    • Pull the top of the motherboard up and out of the device.
  8. Ring Outdoor Security Cam Camera Replacement: Schritt 8, Bild 1 von 2 Ring Outdoor Security Cam Camera Replacement: Schritt 8, Bild 2 von 2
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Then remove the three plastic spacers on the device.
  9. Ring Outdoor Security Cam Camera Replacement: Schritt 9, Bild 1 von 3 Ring Outdoor Security Cam Camera Replacement: Schritt 9, Bild 2 von 3 Ring Outdoor Security Cam Camera Replacement: Schritt 9, Bild 3 von 3
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
Abschluss
WilliamB22
941 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 32
Insgesamt: 178
