Zum Hauptinhalt wechseln
Ring Outdoor Security Cam Microphone Replacement
Was du brauchst
  1. Ring Outdoor Security Cam Microphone Replacement, Microphone: Schritt 1, Bild 1 von 1
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Microphone Replacement: Schritt 2, Bild 1 von 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Microphone Replacement: Schritt 3, Bild 1 von 1
    • Use an opening tool to pry the back plate off of the device.
  4. Ring Outdoor Security Cam Microphone Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Microphone Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  6. Ring Outdoor Security Cam Microphone Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the 3 silver 6 mm Phillips #00 screws from the motherboard.
  7. Ring Outdoor Security Cam Microphone Replacement: Schritt 7, Bild 1 von 1
    • Pull the top of the motherboard up and out of the device.
  8. Ring Outdoor Security Cam Microphone Replacement: Schritt 8, Bild 1 von 2 Ring Outdoor Security Cam Microphone Replacement: Schritt 8, Bild 2 von 2
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Remove the 3 plastic spacers on the device.
  9. Ring Outdoor Security Cam Microphone Replacement: Schritt 9, Bild 1 von 3 Ring Outdoor Security Cam Microphone Replacement: Schritt 9, Bild 2 von 3 Ring Outdoor Security Cam Microphone Replacement: Schritt 9, Bild 3 von 3
    • Pry the motherboard out with a plastic opening tool
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
  10. Ring Outdoor Security Cam Microphone Replacement: Schritt 10, Bild 1 von 1
    • Remove the microphone.
Abschluss
WilliamB22
941 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 54
