Einleitung
If you are having trouble with the motion-activated lights and you would like to replace them, follow the 4 steps that are provided. It will take approximately 15-35 minutes.
Was du brauchst
Use the metal spudger set to break the glue lining and the motion sensor will pop out.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
this showed nothing about replacing the light bulb
This is not a complete how to. The directions stop in the middle and don't show the replacement of the LEDs. Also no parts link for the replacement LED strips
