Einleitung
If your Mounting Bracket is broken or you need to replace it, then you will need to follow these steps to effectively replace the Mounting Bracket.
Was du brauchst
Place Mounting Bracket with lower elevation facing towards you.
Fast fertig!
Abschluss
Ein Kommentar
I have lost the single bracket screw. Where can I get a replacement?
