Zum Hauptinhalt wechseln
Ring Stick Up Cam Battery Replacement
Was du brauchst
  1. Ring Stick Up Cam Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Battery Replacement: Schritt 2, Bild 1 von 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Battery Replacement: Schritt 4, Bild 1 von 1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Battery Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Battery Replacement: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
UC Davis, Team S18-G3, Lore Winter 2019 Mitglied von UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Mitglieder
8 Anleitungen geschrieben
11 Kommentare
Where can I get a replacement battery?
jbains - Antwort
Bad news,
After three different calls to the Ring customer service line (just to be certain i was getting the true honest answer each time) i was told that the Ring stickup 1st generation cam - the one in this section is not available and never was. They suggest that this model was never intended yo be dissected as easy as we know it is. the best we can do is to find someone selling one with a damaged camera and removing its battery. That was how i was able to get my 1st gen stickup back in service again.
Dave S -
No reason to try this, no battery replacement? Have searched the Internet, can’t find a replacement!
Robert Byrum - Antwort
Why would they not use the same simple replaceable battery system as the ring doorbell2
Peter Lasnick - Antwort
Would love to replace the battery, if I could find it online…
Matthew Grow - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 90
Insgesamt: 11,857
