Einleitung
In this guide, we will show you how to replace the microphone in a Ring Stick Up Cam. You will need a Phillips #00 screwdriver and a plastic opening tool.
Was du brauchst
Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
Use your hands to remove the daughterboard containing the microphone from the housing.
