Zum Hauptinhalt wechseln
Ring Stick Up Cam Speakers Replacement
Was du brauchst
  1. Ring Stick Up Cam Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Speakers Replacement: Schritt 2, Bild 1 von 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Speakers Replacement: Schritt 4, Bild 1 von 1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Speakers Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Speakers Replacement: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  7. Ring Stick Up Cam Speakers Replacement, Camera: Schritt 7, Bild 1 von 1
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Speakers Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Speakers Replacement: Schritt 9, Bild 1 von 1
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Speakers Replacement: Schritt 10, Bild 1 von 1
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Speakers Replacement: Schritt 11, Bild 1 von 1
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Speakers Replacement: Schritt 12, Bild 1 von 1
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Speakers Replacement: Schritt 13, Bild 1 von 1
    • Lift the camera board out of the housing using your hand.
  14. Ring Stick Up Cam Speakers Replacement, Microphone: Schritt 14, Bild 1 von 1
    • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
  15. Ring Stick Up Cam Speakers Replacement: Schritt 15, Bild 1 von 1
    • Use a plastic opening tool to carefully pry the microphone from the housing.
  16. Ring Stick Up Cam Speakers Replacement: Schritt 16, Bild 1 von 1
    • Use your hands to remove the daughterboard containing the microphone from the housing.
  17. Ring Stick Up Cam Speakers Replacement, Speakers: Schritt 17, Bild 1 von 1
    • Using a plastic opening tool, remove both of the speakers.
Abschluss
Chunyue Liu
273 Reputation
2 Anleitungen geschrieben
UC Davis, Team S18-G3, Lore Winter 2019 Mitglied von UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 1,096
