Einleitung
To see how to disassemble it, check this other guide on this same site.
Battery made of 2 units and a controller card with a 5-wire output. This battery can possibly be replaced by another one of the same final voltage, either by a parallel arrangement or by a direct connection of a unit.
The final amperage doesn´t need to be the same as the original battery.
The shape of the new battery doesn´t need to be the same either, since it can be placed externally just by inserting the cables.
Both options, using the controller card to facilitate the connection to the main motherboard, so it can recognize the power source.
The main motherboard with antenna card, and the chance of upgrading it with a generic antenna, improving reception and transmission.
To reassemble your device, follow these instructions in reverse order
100%
Penny hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
