Zum Hauptinhalt wechseln
Ring Video Doorbell Speakers Replacement
Was du brauchst
  1. Ring Video Doorbell  Speakers Replacement, Motherboard: Schritt 1, Bild 1 von 3 Ring Video Doorbell  Speakers Replacement, Motherboard: Schritt 1, Bild 2 von 3 Ring Video Doorbell  Speakers Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Ring Video Doorbell  Speakers Replacement: Schritt 2, Bild 1 von 3 Ring Video Doorbell  Speakers Replacement: Schritt 2, Bild 2 von 3 Ring Video Doorbell  Speakers Replacement: Schritt 2, Bild 3 von 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
    Frag FixBot
  3. Ring Video Doorbell  Speakers Replacement: Schritt 3, Bild 1 von 3 Ring Video Doorbell  Speakers Replacement: Schritt 3, Bild 2 von 3 Ring Video Doorbell  Speakers Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
    Frag FixBot
  4. Ring Video Doorbell  Speakers Replacement: Schritt 4, Bild 1 von 2 Ring Video Doorbell  Speakers Replacement: Schritt 4, Bild 2 von 2
    • Detach the upper part of the motherboard from the bottom, using your hands.
    Frag FixBot
  5. Ring Video Doorbell  Speakers Replacement, Speakers: Schritt 5, Bild 1 von 1
    • Speakers are two small rectangles located above the button of the doorbell.
    Frag FixBot
  6. Ring Video Doorbell  Speakers Replacement: Schritt 6, Bild 1 von 1
    • To remove the speakers pry each one out carefully with a plastic opening tool.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S11-G5, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Mitglieder
10 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
Jeffrey Lang - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 81
Insgesamt: 5,988
