Zum Hauptinhalt wechseln
Ring Video Doorbell 3 Camera Sensor Replacement
Was du brauchst
  1. Ring Video Doorbell 3 Camera Sensor Replacement, Faceplate: Schritt 1, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement, Faceplate: Schritt 1, Bild 2 von 2
    • Look at the bottom of the device and locate the arrow.
    • Use your fingers to push the silver faceplate in the direction of the arrow.
    Frag FixBot
  2. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 2, Bild 1 von 1
    • Push up to take the face plate off.
    Frag FixBot
  3. Ring Video Doorbell 3 Camera Sensor Replacement, Battery: Schritt 3, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement, Battery: Schritt 3, Bild 2 von 2
    • Push in the silver tab and slide the battery out.
    Frag FixBot
  4. Ring Video Doorbell 3 Camera Sensor Replacement, Motherboard: Schritt 4, Bild 1 von 3 Ring Video Doorbell 3 Camera Sensor Replacement, Motherboard: Schritt 4, Bild 2 von 3 Ring Video Doorbell 3 Camera Sensor Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Remove the 6 screws with a Torx T6 screwdriver.
    • Remove the 2 screws with a Torx T5 screwdriver.
    Frag FixBot
  5. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 5, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 5, Bild 2 von 2
    • Put your thumb where the battery was and push outwards to remove the back case.
    Frag FixBot
  6. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 6, Bild 1 von 3 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 6, Bild 2 von 3 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 6, Bild 3 von 3
    • Get a tweezer, and remove the black and grey antenna wires.
    Frag FixBot
  7. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 7, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the camera sensor.
    Frag FixBot
  8. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 8, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Be cautious to not rip the ribbon cable.
    • Lift the black tab above the ribbon to unlock it.
    • Use the tweezers to pull out the ribbon.
    Frag FixBot
  9. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 9, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 9, Bild 2 von 2
    • Use a Torx T6 but to take out the four screws on the first motherboard.
    Frag FixBot
  10. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 10, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 10, Bild 2 von 2
    • Use an opening tool to take out the motherboard.
    • Make sure to push in the 5 pins while taking out the motherboards to ensure that they do not break.
    Frag FixBot
  11. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 11, Bild 1 von 1
    • The motherboard has been taken out, and now it is free to be replaced or worked on.
    Frag FixBot
  12. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 12, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 12, Bild 2 von 2
    • Flip the two boards on the side.
    • Gently pull the motherboard and the camera board apart.
    Frag FixBot
  13. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 13, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 13, Bild 2 von 2
    • Use the Phillips #00 screwdriver to remove the two screws.
    Frag FixBot
  14. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 14, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 14, Bild 2 von 2
    • Carefully remove the camera lens from the board.
    • Replace Motherboard(s) if needed.
    • Replace Camera if needed.
    Frag FixBot
  15. Ring Video Doorbell 3 Camera Sensor Replacement, Camera Sensor: Schritt 15, Bild 1 von 1
    • After setting the motherboard aside, grab the case.
    Frag FixBot
  16. Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 16, Bild 1 von 2 Ring Video Doorbell 3 Camera Sensor Replacement: Schritt 16, Bild 2 von 2
    • Desolder these three spots with 4 points and remove the solder.
    • Carefully peel off the camera sensor to remove it
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 37
Insgesamt: 731
