Zum Hauptinhalt wechseln
Ring Video Doorbell Battery Replacement
Was du brauchst
  1. Ring Video Doorbell Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Ring Video Doorbell Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Ring Video Doorbell Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: Schritt 2, Bild 1 von 3 Ring Video Doorbell Battery Replacement: Schritt 2, Bild 2 von 3 Ring Video Doorbell Battery Replacement: Schritt 2, Bild 3 von 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Abdulrahman
685 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S11-G5, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
Where do I get a replacement battery?
William Price - Antwort
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - Antwort
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - Antwort
can it be sent to the manufacturers for a replacement
d.rayyan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 82
Letzte 30 Tage: 332
Insgesamt: 8,606
