Zum Hauptinhalt wechseln
Ripped Soccer Cleat Repair Technique
Was du brauchst
    1. Ripped Soccer Cleat Repair Technique, Ripped Soccer Cleat: Schritt 1, Bild 1 von 1
      • Using a toothbrush, clean the entire cleat, especially where the shoe is ripped.
      • The toothbrush will help get any excess dirt or turf out from under the ripped area.
      Frag FixBot
      Kommentar hinzufügen
    2. Ripped Soccer Cleat Repair Technique: Schritt 2, Bild 1 von 1
      • Squeeze out a good amount of the Shoe Goo onto the piece of printer paper.
      • Shoe Goo will help adhere the sole of the cleat to the leather.
      • Be sure to have a clean air source in the room, as this glue has strong fumes.
      Frag FixBot
    3. Ripped Soccer Cleat Repair Technique: Schritt 3, Bild 1 von 2 Ripped Soccer Cleat Repair Technique: Schritt 3, Bild 2 von 2
      • Using the paint brush, paint the glue in the opening of the ripped cleat and between the leather and the sole of the cleat.
      • The glue is very sticky and dries fast. Make sure to paint it inside the rip as soon as you squeeze the glue out onto the paper.
      • Let dry for 3 minutes and repeat the step again.
      Frag FixBot
    4. Ripped Soccer Cleat Repair Technique: Schritt 4, Bild 1 von 2 Ripped Soccer Cleat Repair Technique: Schritt 4, Bild 2 von 2
      • Press the cleat together firmly and wrap a few pieces of newspaper around the sole of the shoe.
      • The newspaper helps the glue not get stuck to anything.
      Frag FixBot
    5. Ripped Soccer Cleat Repair Technique: Schritt 5, Bild 1 von 2 Ripped Soccer Cleat Repair Technique: Schritt 5, Bild 2 von 2
      • Wrap the adhesive tape around the newspaper tightly to keep pressure on the tear until the glue dries.
      • The adhesive tape keeps pressure on the tear while it dries.
      Frag FixBot
    6. Ripped Soccer Cleat Repair Technique: Schritt 6, Bild 1 von 1
      • Use a hair dryer to slowly warm the newspaper surrounding the tear. Do this for 10 minutes, then let the shoe rest.
      • Make sure to hold the hair dryer 4-6 inches away so the tape and newspaper don't over heat as glue might bubble.
      Frag FixBot
    7. Ripped Soccer Cleat Repair Technique: Schritt 7, Bild 1 von 2 Ripped Soccer Cleat Repair Technique: Schritt 7, Bild 2 von 2
      • After 24 hours, remove the tape and newspaper.
      • Then once the tape and newspaper are removed, peel off any excess glue that is stuck around the area of the rip.
      Frag FixBot
Abschluss
Once the steps above are completed, your cleats should be repaired and ready for play!
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 22
Letzte 30 Tage: 111
Insgesamt: 24,852
