Zum Hauptinhalt wechseln
Rival CM4015 Heating Element Replacement
Was du brauchst
    1. Rival CM4015 Heating Element Replacement, Base Plate: Schritt 1, Bild 1 von 2 Rival CM4015 Heating Element Replacement, Base Plate: Schritt 1, Bild 2 von 2
      • Remove the three 16 mm tri-point screws from the base plate.
      Frag FixBot
      Kommentar hinzufügen
    2. Rival CM4015 Heating Element Replacement: Schritt 2, Bild 1 von 2 Rival CM4015 Heating Element Replacement: Schritt 2, Bild 2 von 2
      • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
      Frag FixBot
    1. Rival CM4015 Heating Element Replacement, Power Button: Schritt 3, Bild 1 von 1
      • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
      Frag FixBot
    2. Rival CM4015 Heating Element Replacement: Schritt 4, Bild 1 von 2 Rival CM4015 Heating Element Replacement: Schritt 4, Bild 2 von 2
      • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
      • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
      Frag FixBot
    3. Rival CM4015 Heating Element Replacement: Schritt 5, Bild 1 von 2 Rival CM4015 Heating Element Replacement: Schritt 5, Bild 2 von 2
      • Clean both the button and its slot before replacing the power button.
      Frag FixBot
    1. Rival CM4015 Heating Element Replacement, Heating Element: Schritt 6, Bild 1 von 1
      • Remove the two 8 mm Phillips screws from the plastic body.
      Frag FixBot
    2. Rival CM4015 Heating Element Replacement: Schritt 7, Bild 1 von 2 Rival CM4015 Heating Element Replacement: Schritt 7, Bild 2 von 2
      • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
      • Pull back the metal backing from the plastic body.
      Frag FixBot
    3. Rival CM4015 Heating Element Replacement: Schritt 8, Bild 1 von 3 Rival CM4015 Heating Element Replacement: Schritt 8, Bild 2 von 3 Rival CM4015 Heating Element Replacement: Schritt 8, Bild 3 von 3
      • Remove the four 8 mm Phillips screws from the inner plastic body.
      • You will need a long, thin Phillips screw driver to get this deep into the device.
      Frag FixBot
    4. Rival CM4015 Heating Element Replacement: Schritt 9, Bild 1 von 2 Rival CM4015 Heating Element Replacement: Schritt 9, Bild 2 von 2
      • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
      • Take your time to make sure the thin cables within the device don't tear.
      Frag FixBot
    5. Rival CM4015 Heating Element Replacement: Schritt 10, Bild 1 von 1
      • Remove the two 8 mm Phillips screws from the metal backing.
      Frag FixBot
    6. Rival CM4015 Heating Element Replacement: Schritt 11, Bild 1 von 1
      • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
      • You may also use pliers for this step if the springs are too strong.
      Frag FixBot
    7. Rival CM4015 Heating Element Replacement: Schritt 12, Bild 1 von 1
      • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 10-6, Livingston Fall 2016 Mitglied von Cal Poly, Team 10-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G6
5 Mitglieder
19 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 680
