Zum Hauptinhalt wechseln
Rival CM4015 Water Tubes Replacement
Was du brauchst
  1. Rival CM4015 Water Tubes Replacement, Base Plate: Schritt 1, Bild 1 von 2 Rival CM4015 Water Tubes Replacement, Base Plate: Schritt 1, Bild 2 von 2
    • Remove the three 16 mm tri-point screws from the base plate.
    Frag FixBot
    Kommentar hinzufügen
  2. Rival CM4015 Water Tubes Replacement: Schritt 2, Bild 1 von 2 Rival CM4015 Water Tubes Replacement: Schritt 2, Bild 2 von 2
    • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
    Frag FixBot
  3. Rival CM4015 Water Tubes Replacement, Power Button: Schritt 3, Bild 1 von 1
    • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
    Frag FixBot
  4. Rival CM4015 Water Tubes Replacement: Schritt 4, Bild 1 von 2 Rival CM4015 Water Tubes Replacement: Schritt 4, Bild 2 von 2
    • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
    • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
    Frag FixBot
  5. Rival CM4015 Water Tubes Replacement: Schritt 5, Bild 1 von 2 Rival CM4015 Water Tubes Replacement: Schritt 5, Bild 2 von 2
    • Clean both the button and its slot before replacing the power button.
    Frag FixBot
  6. Rival CM4015 Water Tubes Replacement, Heating Element: Schritt 6, Bild 1 von 1
    • Remove the two 8 mm Phillips screws from the plastic body.
    Frag FixBot
  7. Rival CM4015 Water Tubes Replacement: Schritt 7, Bild 1 von 2 Rival CM4015 Water Tubes Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
    • Pull back the metal backing from the plastic body.
    Frag FixBot
  8. Rival CM4015 Water Tubes Replacement: Schritt 8, Bild 1 von 3 Rival CM4015 Water Tubes Replacement: Schritt 8, Bild 2 von 3 Rival CM4015 Water Tubes Replacement: Schritt 8, Bild 3 von 3
    • Remove the four 8 mm Phillips screws from the inner plastic body.
    • You will need a long, thin Phillips screw driver to get this deep into the device.
    Frag FixBot
  9. Rival CM4015 Water Tubes Replacement: Schritt 9, Bild 1 von 2 Rival CM4015 Water Tubes Replacement: Schritt 9, Bild 2 von 2
    • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
    • Take your time to make sure the thin cables within the device don't tear.
    Frag FixBot
  10. Rival CM4015 Water Tubes Replacement: Schritt 10, Bild 1 von 1
    • Remove the two 8 mm Phillips screws from the metal backing.
    Frag FixBot
  11. Rival CM4015 Water Tubes Replacement: Schritt 11, Bild 1 von 1
    • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
    • You may also use pliers for this step if the springs are too strong.
    Frag FixBot
  12. Rival CM4015 Water Tubes Replacement: Schritt 12, Bild 1 von 1
    • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
    Frag FixBot
  13. Rival CM4015 Water Tubes Replacement, Water Tubes: Schritt 13, Bild 1 von 1
    • Remove the two rubber water tubes from the heating element by firmly pulling each at a 90 degree angle from the socket.
    Frag FixBot
Abschluss
Cal Poly, Team 10-6, Livingston Fall 2016 Mitglied von Cal Poly, Team 10-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G6
5 Mitglieder
18 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 495
