Einleitung
The following is a simple disassembly guide for the Rival Crock-ette 1 Quart Slow Cooker 3205. Please follow the guide and be cautious when touching the dissembled metal, as it is very sharp and can result in injury.
This disassembly guide can help indicate what parts need to be replaced if anything in the machine is not working correctly.
Before disassembly, fully clean and make sure that the device is unplugged from any power source and is fully cooled down from its last use.
Here, you will simply unscrew the bolt holding the bottom onto the rest of the pot, and then the machine's insides will be visible and ready to be altered.
Was du brauchst
Using pliers, pry the notches on the sides away from the metal and pull until the sides separate.
