Einleitung
A sender that is unresponsive in connection mode may indicate a problem with the wireless connection chip within the device. Replacing a faulty chip can help restore the device's function. This guide will help users replace a faulty wireless module chip indicated by an unresponsive connection between the sender and receiver devices.
Was du brauchst
Remove the 4 rubber tabs on the bottom side of the receiver.
Unscrew the 10 mm screw holding the wireless audio module.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Slide the black retaining flap securing the ribbon cable away from the white bar.
Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
To install the new wireless audio module chip, follow these instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
