Zum Hauptinhalt wechseln
Rocketfish RF-WSP313 Speaker Replacement
Was du brauchst
  1. Rocketfish RF-WSP313 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Using the metal spudger, remove the outer cap from the top of the device.
  2. Rocketfish RF-WSP313 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 cm flathead screws attaching the metal ring to the top of the device.
  3. Rocketfish RF-WSP313 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the ring and set aside.
  4. Rocketfish RF-WSP313 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Using the metal spudger, remove the cap from the bottom of the device.
  5. Rocketfish RF-WSP313 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 sm screws attaching the metal ring to the bottom of the device.
  6. Rocketfish RF-WSP313 Speaker Replacement: Schritt 6, Bild 1 von 1
  7. Rocketfish RF-WSP313 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Using a Phillips # 1 screwdriver, remove the four 1 cm screws from the outside panel. You will do this for each panel; it does not matter which side you start with.
  8. Rocketfish RF-WSP313 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Using the metal spudger, pry off the side panel. Repeat this step on the other side panel.
  9. Rocketfish RF-WSP313 Speaker Replacement: Schritt 9, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the four 1.1 cm flathead screws from the side of the device. Repeat this step on the other side of the device.
  10. Rocketfish RF-WSP313 Speaker Replacement: Schritt 10, Bild 1 von 2 Rocketfish RF-WSP313 Speaker Replacement: Schritt 10, Bild 2 von 2
    • Using the metal spudger, open the device.
  11. Rocketfish RF-WSP313 Speaker Replacement: Schritt 11, Bild 1 von 2 Rocketfish RF-WSP313 Speaker Replacement: Schritt 11, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using your fingers (or a pair of tweezers), disconnect the speaker cord from its socket.
  12. Rocketfish RF-WSP313 Speaker Replacement: Schritt 12, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the four 1.2 cm pan head screws surrounding the speaker.
  13. Rocketfish RF-WSP313 Speaker Replacement: Schritt 13, Bild 1 von 1
    • Remove the speaker from the device.
Abschluss
Kara Falknor
101 Reputation
1 Anleitung geschrieben
Washington State, Team 1-50, Staggers Spring 2017 Mitglied von Washington State, Team 1-50, Staggers Spring 2017
WSU-STAGGERS-S17S1G50
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 563
