Einleitung
This guide will show you how to remove the components of the product necessary to access the bluetooth speaker, remove it, and replace it with a new one.
Was du brauchst
Using the metal spudger, remove the outer cap from the top of the device.
Using a Phillips # 1 screwdriver, remove the four 1.1 cm flathead screws attaching the metal ring to the top of the device.
Using a Phillips # 1 screwdriver, remove the four 1.1 sm screws attaching the metal ring to the bottom of the device.
Using a Phillips # 1 screwdriver, remove the four 1 cm screws from the outside panel. You will do this for each panel; it does not matter which side you start with.
Using the metal spudger, pry off the side panel. Repeat this step on the other side panel.
Using a Phillips #1 screwdriver, remove the four 1.1 cm flathead screws from the side of the device. Repeat this step on the other side of the device.
Using a Phillips #1 screwdriver, remove the four 1.2 cm pan head screws surrounding the speaker.
