Einleitung
All individual parts can be replaced on the motherboard as well. Please see additional guides if needed.
Was du brauchst
Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
Pull back the rubber protection in the top right corner to locate the screw.
Repeat with the bottom right corner and bottom left corner.
Open the device by gently lifting the bottom half away from the top half of the device.
Use your fingers to carefully lift the motherboard from the top half of the device.
6 weitere Personen haben diese Anleitung absolviert.
