Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If there continues to be a problem after restarting and repairing the remote, you may need to replace or fix your remote's motherboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place the remote control facing down on the table, so that the buttons are facing downwards.
    • Place the remote control facing down on the table, so that the buttons are facing downwards.
  2. Remove the battery compartment cover from the back of the remote by sliding it outwards.  This should reveal the batteries. Remove the battery compartment cover from the back of the remote by sliding it outwards.  This should reveal the batteries.
    • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
  3. Remove the batteries from the battery compartment. Remove the batteries from the battery compartment.
    • Remove the batteries from the battery compartment.
  4. Turn the  Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both  battery compartments .
    • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
  5. Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
    • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
    • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
  6. Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing. Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing. Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
    • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Hank Harrison
386 Reputation
3 Anleitungen geschrieben
Baylor, Team S5-G4, Williams Spring 2017 Mitglied von Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Mitglieder
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 24
Insgesamt: 992
