Einleitung
The Roku Streaming Stick remote is a device that is used to control the operation of the Roku from a distance. This guide will provide instructions on how to replace the macro buttons.
Was du brauchst
Place the remote so that the battery cover is facing upwards.
Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
