Zum Hauptinhalt wechseln
Roku Streaming Stick Macro Button Contacts Replacement
Was du brauchst
  1. Roku Streaming Stick Macro Button Contacts Replacement, Macro Button Contacts: Schritt 1, Bild 1 von 1
    • Place the remote so that the battery cover is facing upwards.
  2. Roku Streaming Stick Macro Button Contacts Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover to expose the battery compartment.
  3. Roku Streaming Stick Macro Button Contacts Replacement: Schritt 3, Bild 1 von 1
    • Remove batteries.
  4. Roku Streaming Stick Macro Button Contacts Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
  5. Roku Streaming Stick Macro Button Contacts Replacement: Schritt 5, Bild 1 von 2 Roku Streaming Stick Macro Button Contacts Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
  6. Roku Streaming Stick Macro Button Contacts Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the circuit board or motherboard.
  7. Roku Streaming Stick Macro Button Contacts Replacement: Schritt 7, Bild 1 von 1
    • First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
    • Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
Abschluss
Feliciano Bandazi
145 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G2, Wilson Spring 2018 Mitglied von IUPUI, Team S2-G2, Wilson Spring 2018
IUPUI-WILSON-S18S2G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 3,452
