Einleitung
This guide demonstrates how to install a roll pin and bearing into a bearing carrier for your Electric Eel 75’ Drain Cleaner Z5K12IC75AF.
Was du brauchst
Use a vise to compress the roll pin until there is no longer space in the roll pin's slot.
Use a dead blow hammer or mallet to tap down the bearing carrier onto the roll pin until the pin just begins to peek into the bearing channel.
Continue to tap down the bearing carrier until the bearing and spacer are fully secured around the roll pin.
