Einleitung
This guide explains how to completely teardown the Rosewill NEON M62 mouse. This repair should be performed when something needs to be replaced internally.
Was du brauchst
Place the mouse so the bottom is facing upwards.
Remove the plastic skates.
Remove the two 5 mm screws with a Phillips #00 screwdriver.
Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
Fast fertig!
Abschluss
