Einleitung
This guide explains how to remove the plastic sensor cover in the Rosewill NEON M62 mouse. This should be done if the mouse is plugged into a computer, when the mouse is moved, the cursor does not respond.
Was du brauchst
Place the mouse so the bottom is facing upwards.
Remove the plastic skates.
Remove the two 5 mm screws with a Phillips #00 screwdriver.
Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
