Zum Hauptinhalt wechseln
RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement
Was du brauchst
  1. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Saw Casing: Schritt 1, Bild 1 von 1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 2, Bild 1 von 2 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 2, Bild 2 von 2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 3, Bild 1 von 2 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 3, Bild 2 von 2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 4, Bild 1 von 1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 5, Bild 1 von 2 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 5, Bild 2 von 2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Motor: Schritt 6, Bild 1 von 1
    • Lift the motor assembly out of the casing.
    • The white plastic piece connecting the wires and holding the motor brushes in place is fragile. Be careful to not break it when removing the motor assembly.
  7. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 7, Bild 1 von 2 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 7, Bild 2 von 2
    • Detach the wire connected to the bottom of the motor assembly.
    • Rotate the motor away from you so that the second wire is visible, and detach that wire as well.
  8. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Safety Lock Pin: Schritt 8, Bild 1 von 1
    • Remove the sliding washer holding the pin in place.
    • The sliding washer is not shown in this guide. The action shows where the washer should be located.
  9. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: Schritt 9, Bild 1 von 1
    • Flip the saw so that the 'Rotozip' label is facing upwards.
    • Remove the safety lock pin and spring.
Abschluss
Lauren Russell
224 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-4, Livingston Fall 2016 Mitglied von Cal Poly, Team 4-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G4
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Where can I find replacement parts for this Particular rotozip model #reb01 type 2
Kennith Murray - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 2,276
