Zum Hauptinhalt wechseln
Rowenta Focus Heating Element and Soleplate Replacement
Was du brauchst
  1. Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: Schritt 1, Bild 1 von 2 Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: Schritt 1, Bild 2 von 2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 2, Bild 1 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 2, Bild 2 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 2, Bild 3 von 3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 3, Bild 1 von 2 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 3, Bild 2 von 2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 4, Bild 1 von 2 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 4, Bild 2 von 2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 5, Bild 1 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 5, Bild 2 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 5, Bild 3 von 3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
  6. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: Schritt 6, Bild 1 von 3 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: Schritt 6, Bild 2 von 3 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: Schritt 6, Bild 3 von 3
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
  7. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 7, Bild 1 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 7, Bild 2 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 7, Bild 3 von 3
    • Replace with an identical part by inserting it into the space.
  8. Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: Schritt 8, Bild 1 von 2 Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: Schritt 8, Bild 2 von 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
  9. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 9, Bild 1 von 2 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 9, Bild 2 von 2
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
  10. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 10, Bild 1 von 2 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 10, Bild 2 von 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
  11. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 11, Bild 1 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 11, Bild 2 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 11, Bild 3 von 3
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
  12. Rowenta Focus Heating Element and Soleplate Replacement: Schritt 12, Bild 1 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 12, Bild 2 von 3 Rowenta Focus Heating Element and Soleplate Replacement: Schritt 12, Bild 3 von 3
    • Lift the iron up using the handle to completely detach the soleplate.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Bella Navarro
450 Reputation
3 Anleitungen geschrieben
University of Alabama, Team 2-3, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-3, Bedsole Fall 2021
UA-BEDSOLE-F21S2G3
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
hi how do i clean sole plate inside ??????????????????? wath sort of sealent do they use to seal it or where do you get it from????????????????
Willie Waldner - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 84
Insgesamt: 4,451
