Zum Hauptinhalt wechseln
Rowenta Focus Material Setting Knob Replacement
Was du brauchst
  1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: Schritt 1, Bild 1 von 2 Rowenta Focus Material Setting Knob Replacement, Power Assembly: Schritt 1, Bild 2 von 2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Material Setting Knob Replacement: Schritt 2, Bild 1 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 2, Bild 2 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 2, Bild 3 von 3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Material Setting Knob Replacement: Schritt 3, Bild 1 von 2 Rowenta Focus Material Setting Knob Replacement: Schritt 3, Bild 2 von 2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Material Setting Knob Replacement: Schritt 4, Bild 1 von 2 Rowenta Focus Material Setting Knob Replacement: Schritt 4, Bild 2 von 2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Material Setting Knob Replacement: Schritt 5, Bild 1 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 5, Bild 2 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 5, Bild 3 von 3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
  6. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: Schritt 6, Bild 1 von 3 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: Schritt 6, Bild 2 von 3 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: Schritt 6, Bild 3 von 3
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
  7. Rowenta Focus Material Setting Knob Replacement: Schritt 7, Bild 1 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 7, Bild 2 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 7, Bild 3 von 3
    • Replace with an identical part by inserting it into the space.
  8. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: Schritt 8, Bild 1 von 2 Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: Schritt 8, Bild 2 von 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
  9. Rowenta Focus Material Setting Knob Replacement: Schritt 9, Bild 1 von 2 Rowenta Focus Material Setting Knob Replacement: Schritt 9, Bild 2 von 2
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
  10. Rowenta Focus Material Setting Knob Replacement: Schritt 10, Bild 1 von 2 Rowenta Focus Material Setting Knob Replacement: Schritt 10, Bild 2 von 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
  11. Rowenta Focus Material Setting Knob Replacement: Schritt 11, Bild 1 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 11, Bild 2 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 11, Bild 3 von 3
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
  12. Rowenta Focus Material Setting Knob Replacement: Schritt 12, Bild 1 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 12, Bild 2 von 3 Rowenta Focus Material Setting Knob Replacement: Schritt 12, Bild 3 von 3
    • Lift the iron up using the handle to completely detach the soleplate.
  13. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: Schritt 13, Bild 1 von 3 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: Schritt 13, Bild 2 von 3 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: Schritt 13, Bild 3 von 3
    • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
  14. Rowenta Focus Material Setting Knob Replacement: Schritt 14, Bild 1 von 2 Rowenta Focus Material Setting Knob Replacement: Schritt 14, Bild 2 von 2
    • Turn the iron over and pull the knob off.
    • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Bella Navarro
426 Reputation
3 Anleitungen geschrieben
University of Alabama, Team 2-3, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-3, Bedsole Fall 2021
UA-BEDSOLE-F21S2G3
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 44
Insgesamt: 960
