Zum Hauptinhalt wechseln
Einleitung
This guide provides an understanding of how to replace the cooling fan inside of a Royal Sovereign electric heater. Electric Heaters are used daily during the winter season and sometimes they can overheat due to defects in the cooling fan. This guide will show you how to disassemble the heater and replace the fan. This way, you can keep using the heater for a longer period of time.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Royal Sovereign Fan Replacement, Fan: Schritt 1, Bild 1 von 2 Royal Sovereign Fan Replacement, Fan: Schritt 1, Bild 2 von 2
    • Make sure that the heater is unplugged and completely cooled down.
    • Turn the heater so the back is facing up.
    • Remove all six 14 mm screws using the Philips #0 screwdriver.
  2. Royal Sovereign Fan Replacement: Schritt 2, Bild 1 von 1
    • Separate the back case from the heater.
  3. Royal Sovereign Fan Replacement: Schritt 3, Bild 1 von 2 Royal Sovereign Fan Replacement: Schritt 3, Bild 2 von 2
    • You are left with the motor and wires attached to the front case.
    • Use the Phillips #1 screwdriver to remove the four 14 mm screws attaching the motor to the front case..
    • Do not untangle the wires
  4. Royal Sovereign Fan Replacement: Schritt 4, Bild 1 von 2 Royal Sovereign Fan Replacement: Schritt 4, Bild 2 von 2
    • Turn the motor over to reveal the fan.
    • Use a plier to twist and unscrew the hexagonal screw attached to the fan.
  5. Royal Sovereign Fan Replacement: Schritt 5, Bild 1 von 1
    • Take the fan out.
Abschluss
Mohammed Jubair Rabbani
121 Reputation
1 Anleitung geschrieben
York University, Team S1-G21, O'Regan Summer 2021 Mitglied von York University, Team S1-G21, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G21
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 14
Insgesamt: 105
