Zum Hauptinhalt wechseln
Rozia HQ242 Trimmer Spring Replacement
Was du brauchst
  1. Rozia HQ242 Trimmer Spring Replacement, Spring: Schritt 1, Bild 1 von 3 Rozia HQ242 Trimmer Spring Replacement, Spring: Schritt 1, Bild 2 von 3 Rozia HQ242 Trimmer Spring Replacement, Spring: Schritt 1, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws securing the blade to the trimmer.
  2. Rozia HQ242 Trimmer Spring Replacement: Schritt 2, Bild 1 von 2 Rozia HQ242 Trimmer Spring Replacement: Schritt 2, Bild 2 von 2
    • Gently lift the inner blade straight up and away from the device.
    • With the blades removed, now is a good time to clean the trimmer using a small brush, dust blower, or q-tips.
  3. Rozia HQ242 Trimmer Spring Replacement: Schritt 3, Bild 1 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 3, Bild 2 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 3, Bild 3 von 3
    • Gently lift the spring away from the trimmer.
    • You may need to point the legs of the spring at a 45-degree angle before you can pull it out.
    • Take note of the shape of the spring. There is a flat U-shaped bend that rests on a notch in the trimmer. This information will be important when putting everything back together!
  4. Rozia HQ242 Trimmer Spring Replacement: Schritt 4, Bild 1 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 4, Bild 2 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 4, Bild 3 von 3
    • Align the flat U-shaped end of the spring to the notch on the trimmer.
    • Gently pinch the two legs of the spring with your thumb and index finger, aligning them to point towards the front of the trimmer at a 45-degree angle, then drop it into the slot.
    • Once it is successfully in, carefully let go. If it falls off the notch, you will have to wedge it out and try again. This may take multiple attempts.
    • Make sure that the spring is securely resting on the notch, or the trimmer may not function properly!
  5. Rozia HQ242 Trimmer Spring Replacement: Schritt 5, Bild 1 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 5, Bild 2 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 5, Bild 3 von 3
    • Reinstall the inner blade.
    • The notch located on the back of the blade must align with the gold-plated contact.
    • Gently push down so that the plate rests against the front of the trimmer.
    • Take extra caution not to dislodge the spring from its position, especially after pressing down on the blade.
  6. Rozia HQ242 Trimmer Spring Replacement: Schritt 6, Bild 1 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 6, Bild 2 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 6, Bild 3 von 3
    • Carefully reattach the outer blade.
    • The screw holes protrude just enough to allow the blade to 'click' into position.
    • Use a Phillips #1 screwdriver to replace the two 6 mm screws that secure the outer blade.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Jose Lucio
201 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 8-3, Grodsky Spring 2024 Mitglied von CSU Los Angeles, Team 8-3, Grodsky Spring 2024
CSULA-GRODSKY-S24S8G3
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 74
Insgesamt: 651
