Zum Hauptinhalt wechseln
Rubber Watch Battery Replacement
Was du brauchst
  1. Rubber Watch Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Rubber Watch Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Begin by placing the watch on its backside.
  2. Rubber Watch Battery Replacement: Schritt 2, Bild 1 von 3 Rubber Watch Battery Replacement: Schritt 2, Bild 2 von 3 Rubber Watch Battery Replacement: Schritt 2, Bild 3 von 3
    • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
    • Pull out the white cap and green chip once it is free.
  3. Rubber Watch Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
    • Be careful not to insert the X-Acto knife too downward into the battery.
  4. Rubber Watch Battery Replacement: Schritt 4, Bild 1 von 3 Rubber Watch Battery Replacement: Schritt 4, Bild 2 von 3 Rubber Watch Battery Replacement: Schritt 4, Bild 3 von 3
    • Flip the chip around to the front.
    • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
    • Make sure to hold the knife away from the hands in a safe, stable grip.
    • Remove the cut plastic casing over the battery.
    • The plastic casing should come off like a cap.
  5. Rubber Watch Battery Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the battery with a spudger or a wooden coffee stick.
    • Using too much force may detach the tab holding the battery and break the watch.
    • Once free, remove the dead battery.
  6. Rubber Watch Battery Replacement: Schritt 6, Bild 1 von 1
    • Insert the new battery.
    • Place the cut plastic cap casing over the chip and battery.
  7. Rubber Watch Battery Replacement: Schritt 7, Bild 1 von 3 Rubber Watch Battery Replacement: Schritt 7, Bild 2 von 3 Rubber Watch Battery Replacement: Schritt 7, Bild 3 von 3
    • Place the white cap over the green chip.
    • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
    • Turn over the watch and check the power.
Ziellinie
Lee
110 Reputation
1 Anleitung geschrieben
UC Davis, Team S2-G5, Cole Spring 2017 Mitglied von UC Davis, Team S2-G5, Cole Spring 2017
UCD-COLE-S17S2G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 769
