Einleitung
When the gears of a hand mixer are warped or damaged this can cause them block, effectively rendering your mixer useless. Fortunately, it is easy to replace them, making your mixer function as new. If the gears are not damaged but just don’t run smoothly anymore, it’s also possible to clean and lubricate them.
Was du brauchst
Slightly loosen all four 2.54 cm Phillips #1 screws and remove them.
Remove the top casing.
Remove the 1.50 cm Phillips #1 screw that holds the cable clamp.
Remove the cable clamp.
Lay the product on its side and remove the 1.27 cm Phillips #1 screw holding the bottom metal plate in place.
Remove the metal plate holding the gears in place.
Ein Kommentar
Hey, do you have a print file or do you know a place where i can buy these gears? Would really like to repair my own mixer.
