Einleitung
Is your vacuum bumping into everything? Replacing the bumpers may solve the problem.
Was du brauchst
Flip the vacuum over so that the wheels are facing you.
Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
Fast fertig!
Abschluss
