Einleitung
Does your Rydis H68 Pro robot vacuum not power on even after replacing the battery? The motherboard may be defective. Follow this guide on how to change it for a new one!
Was du brauchst
Flip the vacuum over so that the wheels are facing you.
Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
Use a Phillips #1 screwdriver to remove the four 10 mm screws holding the motherboard in place.
Pinch the two tabs together, shown here, to loosen the motherboard out of the vacuum.
Lightly pull on the USB connector shown to lift the motherboard out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
3 Kommentare
This was GREAT.... Lots of pics :-)
I was able to pull the mother board without much trouble. Mostly scared of breaking the connections.
NOW???? Where do I buy the darn thing?
Please respond,
Robert
Unfortunately, it looks like Moneual had some fraud issues and went under in 2014. It may be difficult to get your hands on replacement parts for the Rydis H68 Pro. =[
Richard -
