Einleitung
If you need to replace the motor of the Ryobi CSB135L, you can access the motor by following this guide below.
Was du brauchst
Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
Remove the three M3.5 x 16 mm screws that hold on the laser cover using a Phillips screwdriver.
Pry the motor housing (green plastic) from the blade housing (gray plastic) using a metal spudger or any small pry bar.
Rotate the saw completely around to view the bottom of the motor as shown.
Remove the two 4.2 x 2.54 x 50 screws using a Phillips screwdriver.
Follow the wires from the motor to the wire cover and black box and undo the fastening of those wires to finish removing the motor from the saw.
