Einleitung
If you need to replace or fix and component of the Ryobi P214 cordless drill that is on the inside cast, use this guide to access the inside panel.
Was du brauchst
Detach the battery unit from the drill body and pull the battery outwards.
Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
Grab the sides of the housing and pull straight up until the housing pulls away revealing the inside assembly.
