Einleitung
Safety:
For your safety, ensure the Ryobi D620H Hammer Drill is not connected to any power source before you perform any repairs.
Before reassembly
While wearing disposable nitrile gloves, apply grease all around the mode shift button before reinserting it into the drill's motor assembly. This allows the mode shift button to slide easily when changing modes.
Was du brauchst
All nine 16mm long Torx20 screws (Circled in red).
Turn the screwdriver counterclockwise to loosen the screws.
Remove all nine screws completely.
The mode selector switch (Circled in red) once the right side case is removed.
Push the mode selector switch up (away from the work surface) to dislodge it.
Lift the mode selector switch out of its slot.
To reassemble your device, place the mode shift button in the slot it was removed from at a slight angle and straighten it out as you push it into place.
Congratulations, you have replaced the mode shift button on your Ryobi hammer drill!
Eine weitere Person hat diese Anleitung absolviert.
