Zum Hauptinhalt wechseln
Ryobi D620H Power Cord Replacement
Was du brauchst
  1. Ryobi D620H Power Cord Replacement, Right Side Case: Schritt 1, Bild 1 von 1
    • All nine 16mm long Torx20 screws (Circled in red).
    • Turn the screwdriver counterclockwise to loosen the screws.
    • Remove all nine screws completely.
    • Place in parts tray (Optional)
  2. Ryobi D620H Power Cord Replacement: Schritt 2, Bild 1 von 2 Ryobi D620H Power Cord Replacement: Schritt 2, Bild 2 von 2
    • Pry the right side of the case off to expose the internal components.
  3. Ryobi D620H Power Cord Replacement, Power Cord: Schritt 3, Bild 1 von 1
    • The bend relief cover at the bottom of the handle.
    • Follow the wires coming out of the bend relief cover to the white power cord clamp with the two 14 mm black PH1 screws.
  4. Ryobi D620H Power Cord Replacement: Schritt 4, Bild 1 von 2 Ryobi D620H Power Cord Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the two 14 mm PH1 screws holding the power cord wire in place.
    • Lift the switch box from its place gently.
  5. Ryobi D620H Power Cord Replacement: Schritt 5, Bild 1 von 3 Ryobi D620H Power Cord Replacement: Schritt 5, Bild 2 von 3 Ryobi D620H Power Cord Replacement: Schritt 5, Bild 3 von 3
    • Remove the two little screws holding the brass terminal lugs in place. Although it is not required, you can remove the screws completely if you find that doing so is more convenient.
    • Gently pull the white positive and black negative wires that are connected to the switch box.
    • Slide the bend relief guard off the cord towards the loose connections.
Abschluss
Slide the bend relief cover on the new power cord and reattach all of the electrical connections in reverse order.
Congratulations you've successfully replaced the power cord on your hammer drill!
Jacob da Ponte
469 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 1-2, Petersen Fall 2023 Mitglied von UMass Dartmouth, Team 1-2, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 94
