Zum Hauptinhalt wechseln
Einleitung
This guide demonstrates how to open the drill and remove the gear select switch. Removing the gear select switch does not require disassembling any of the internal electronics of the drill, but it is recommended to remove the battery to reduce shock hazard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. The battery can shock you.  Only touch plastic, non-conductive components. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Gently lift the casing from the drill body. Take the casing completely off the drill body to gain access to the interior of the drill.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Rotate the Drill 180 degrees so that the top is facing you. Lift the level gauge out from the top corner of the drill. The level gauge is Part #: 3000909
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
  5. Lift the gear switch upwards from the top of the drill head. The gear switch is Part #: 341098001
    • Lift the gear switch upwards from the top of the drill head.
    • The gear switch is Part #: 341098001
Abschluss
Joseph Eckstein
1.533 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 17-6, Forte Spring 2015 Mitglied von Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 641
