Einleitung
The bit holder makes it easier to keep the bits you need close to your drill. This guide shows how to replace a missing or broken bit holder on your Ryobi P235.
Was du brauchst
Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
Fast fertig!
Abschluss
