Zum Hauptinhalt wechseln
Ryobi P235 Direction of Rotation Selector Replacement
Was du brauchst
  1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: Schritt 1, Bild 1 von 2 Ryobi P235 Direction of Rotation Selector Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Direction of Rotation Selector Replacement: Schritt 2, Bild 1 von 2 Ryobi P235 Direction of Rotation Selector Replacement: Schritt 2, Bild 2 von 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: Schritt 3, Bild 1 von 2 Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: Schritt 3, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Direction of Rotation Selector Replacement: Schritt 4, Bild 1 von 2 Ryobi P235 Direction of Rotation Selector Replacement: Schritt 4, Bild 2 von 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Direction of Rotation Selector Replacement: Schritt 5, Bild 1 von 2 Ryobi P235 Direction of Rotation Selector Replacement: Schritt 5, Bild 2 von 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Direction of Rotation Selector Replacement: Schritt 6, Bild 1 von 2 Ryobi P235 Direction of Rotation Selector Replacement: Schritt 6, Bild 2 von 2
    • Lift the internal components out of the housing.
  7. Ryobi P235 Direction of Rotation Selector Replacement: Schritt 7, Bild 1 von 2 Ryobi P235 Direction of Rotation Selector Replacement: Schritt 7, Bild 2 von 2
    • Remove the gray plastic forward/reverse selector.
Abschluss
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 Mitglied von UMass Dartmouth, Team S4-G2, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 754
