Einleitung
Use this guide to replace the motor in your Ryobi P235 impact driver if it is overheating or under powered when the battery is fully charged.
The motor is what converts the power stored in the battery to the physical power used to spin the cam shaft and hammer assembly. Since the motor requires the most steps and is the most difficult part to replace, it is important to keep an eye out for any cracked or broken components while taking apart your impact driver.
When you reach steps 12 and 13, the wires are soldered to the motor so a soldering iron will need to be used to disconnect them from the old motor and then reattach them to the new one.
Was du brauchst
Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
Remove the metal pins on each side of the inner case assembly.
Remove the two 8mm screws and spring washers connecting the motor to the inner case assembly.
Separate the two parts.
Use a soldering iron to remove the black and red wires connecting the motor to the trigger assembly.
To reassemble your device, follow these instructions in reverse.
Eine weitere Person hat diese Anleitung absolviert.
