Einleitung
Use this guide to replace the trigger assembly in your Ryobi P235 Impact driver if power isn’t getting to the motor while using a fully charged battery.
The trigger assembly is what regulates how much power gets to the motor and what direction the motor spins.
When you reach step 7 and 8, the wires are soldered to the motor so a soldering iron will need to be used to disconnect them from the old trigger assembly and then reattach them to the new one.
Was du brauchst
Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
Lift the trigger mechanism and other internal components out of the housing assembly.
Use a soldering iron to remove the black and red wires connecting the trigger assembly to the motor.
To reassemble your device, follow these instructions in reverse order starting at step 6.
2 weitere Personen haben diese Anleitung absolviert.
