Einleitung
This guide will instruct the user on replacing the speed selector switch on the Ryobi P277.
Was du brauchst
Lay the device on its side.
Remove eight 5 mm screws using a TR10 Torx screwdriver.
Separate the two halves by pulling up on the top half.
Carefully disconnect the speed selector switch from the metal bar and remove the switch.
Fast fertig!
Abschluss
